Viewing 11 posts - 1 through 11 (of 11 total)
  • Brake Disk adaptor Advice… heads sore from scrathing… post to IS
  • Nickoli
    I have an old set of XT brakes that are IS mount, a 203mm rotor and a shiny new pair of Lyriks with are Post mount…
    I may well be being thick here but I can't locate a suitable adaptor. This is the closet that I have found, 170mm adaptor on CRC
    Any advice greatfully recieved.
    Nick
    clubby
    Nick, I went through this with my hope set up. There is no easy or elegant fix with adaptors. Either sell you old xt and buy a new set or buy a new caliper to use with existing lever. Found these on crc which would work.
    http://www.chainreactioncycles.com/Models.aspx?ModelID=37443
    http://www.chainreactioncycles.com/Models.aspx?ModelID=13747
    Not xt but it should work with your levers. You can always sell spare rotor and mount to get some cash back.
    Personally I sold old set up and bought new set specific for forks.
    MulletusMaximus
    What about this
    clubby
    MM, I may be wrong but I think thats for the other way round. I found the same, there are plenty of adaptors if you have an IS fork and post caliper but not the other way round.
    Mister-P
    Yep that is the wrong way round.
    Nickoli
    Thanks for the advice… and yes Mulletus unforuntately thats the wrong way round.
    It looks like I may have to upgrade to a new set of brakes then… I was considering that option but havent really got the gold reserves for it at the moment.
    Acually, I have access to a workshop. Is there anywhere I could get the required offsets so I could machine up my own?
    Nick
    james
    Giant used to do one
    Was for a 164mm rotor (standard caliper went straight onto a 160mm IS fork normally so the caliper was the +4mm bit
    So it should let you run a 160mm rotor, post mount fork (are lyriks 160mm direct fit? (or 203mm direct fit?) and standard caliper
    Whether or not it will fit around a shimano caliper I don't know but Giant MPH-3 calipers are pretty big
    I never bought one but when I was considering a post mount fork I asked my LBS (JeJames Rotherham) 2 years ago they had them in stock. Ring round some Giant dealers and see if they've got nay left (The MPH brake isn't made any more)
    Hope (and others) do a +40mm adapter if needed
    Nickoli
    THanks for all the info James. Is this the giant adaptor you make reference to? Adaptor
    If so it just looks like a post to post adaptor?
    I believe the lyrics are 160 direct mounts.
    Nick
    Nickoli
    Actually… I think I've just found what I'm after
    A2Z
    padrc66
    i think your choices are 180mm disc with hope adapter:
    http://www.chainreactioncycles.com/Models.aspx?ModelID=13735
    or as you've identified, the a2z adapter, only £11 at woollyhatshop:
    http://www.woollyhatshop.com/view_product.php?id=2111
    Nickoli
    Ordered the A2Z option… many thanks for all your help!
The topic ‘Brake Disk adaptor Advice… heads sore from scrathing… post to IS’ is closed to new replies.
