80% of brake power on the front brake?
if you study the effect that braking has on your bike, hard braking rotates the bicycle against the front wheel axle, lifting the rear wheel off the ground, making the rear brake less effective
you can counter this by leaning right back when making a really hard stop, to try and pin the rear wheel to the ground, but it will always slide when locked up hard
so rear brake is used in combination with front for hard stops, or more commonly rear brake used for adjustment of bike position going into corners
very common to use larger rotor on front, and small rotor on rear
many pro DH racers use 160mm rotor on rear for this reasons (these guys also don’t plan to do much braking on the rear during their run)
