Evening,
Both front and back brakes have gone spongey. This wasn’t sudden, but gradual over 2-3 rides. (Avid Elixr 7)
Brake pads are fine. I’ve rebled both brakes quite a few times. After bleeding if I gently press the lever with the bleed block still in, it feels nice tight – so feels like job done. But, when I put the brake pads back in and pull the lever its spongey and after a few squeezes it loses all pressure. Not sure, but I think there is fluid leaking from the caliper.
Pretty sure it’s not the brake bleed process going wrong – I’ve had friend do it too with the same result.
I was going to buy a new piston/seal kit but thought best to ask here in case there’s any other diagnostics I should do. I wonder, for example, if the fact that both brakes went at virtually the same time is indicative of what the problem might be?
thanks
