I’m renovating a house and the ground floor is seriously on the piss. As far as i can work out it was partly built like that (~1935) and partly moved a bit / joists bowed a little etc.
Anyway, working from the highest point and replacing rotten joists / packing out the plate on the sleeper wall is all fine until I get near the stairs. By the time I level that out and put a chipboard on then the finished flooring, the bottom step on the stairs is going to be something like 50 – 55mm lower in height than the rest of the stairs.
I’m sure I’ll notice, but will it really be an issue? Any thoughts?
