Viewing 16 posts - 1 through 16 (of 16 total)
  • Bottom Brackets Hope v XT
  • rOcKeTdOg
    is the Hope stainless worth the extra cost over the Shimano?
    Elfinsafety
    Yes.
    JamieMc
    XTR ones are good. No experience of XT though
    z1ppy
    Not to me.
    kaesae
    I have some old shimano cups, do you want me to see if I can convert them to run standard INA bearings plus a set of nylon bushes ❓
    Then you can simply recondition your existing shimano BB’s
    Aidan
    I’d say Hope are worth it. They last maybe 4 or 5 times longer than Shimano for me.
    DaveBro
    Hope bb has outlasted XTR and XT by a significant margin (found little difference between XTR and XT in terms of ‘life’), my ‘experimenting is over’ – i will go for Hope from now on.
    kaesae
    I run hope BB cups and the same kind of bearings but it costs me very little to replace them.
    The set in my raceface cubs have lasted a good 12 months so far and are still in very good condition.
    Shop around you’ll find something that will last.
    takisawa2
    The King one had a good report after a years use, in the STW mag.
    tadpole
    my shimano one lasted a year, with a lot of use, my hope one lasted 2 months, though to be fair to hope, they did replace the bearing and cup for free, so i’ll see how long it lasts this time.
    richc
    Just buy an Acros one, 2 year warranty and turns the BB into a fit and forget item.
    Andituk
    Yes. They come in a full range of colours.
    What more do you want?
    Kryton57
    BETD will give them a nice once over:
    Here:
    gravity-slave
    I got the tipoff from here – XTR for £16.95 plus carraige. Still a bargain after the £5.95 and you get a nice free bowl with your first order! Should have got one for spares.
    Low stock right now, but they’ll be back:
    http://www.rosebikes.co.uk/product/detail/aid:274227
    cp
    IMO, yes. I went through so many XT’s & deores and since then, hope has been fit and forget. No stiff bearings after a muddy ride, no ditching after 3-6 months. just keeps working!
    The Hope also appears to me to be more free running – spin the cranks with no chain on the rings, and they just keep going and going!
    oh, and they look very nice too 🙂
    Munqe-chick
    I thought SLX, XT and STR were identical bar the colour, with just the cheaper deore being mechanically different?
    Buy a cheap BB and replace the bearings when they die with either same size and re-use the top caps, or the larger Enduro style ones that run direct onto the axle.
The topic ‘Bottom Brackets Hope v XT’ is closed to new replies.
