Viewing 40 posts - 1 through 40 (of 73 total)
  • Bottom 3 mtbing products
  • kingkongsfinger
    Girvin flex stems
    Dropper posts
    Biopace cranks
    jimthelad
    Dual Control Shifter/Brakes
    Cable Disc Brakes
    Commencal QR Skewers
    Edric64
    29 ER wheels
    Dropper posts
    Shimano external bearings
    PaulD
    Dropper Posts
    U-Brakes
    Green Tyres (foam filled knee-breakers)
    PaulD
    Farmer_John
    can’t remember the name of it but one of those spring things you hung off the rear dropout to put more tension on the rear mech
    IA
    Bullet Bros hypertension you say?
    Bottom bracket
    Bottom bracket tool
    Bottom Bracket spacer
    jota180
    1. Crank Bros xxx
    2. Crank Bros xxx
    3. Crank Bros xxx
    replace xxx with anything they make
    honourablegeorge
    Avid Brakes
    Dual Control
    Scott shocks
    bullroar
    Avid Juicy 3 Brakes
    Torx bolts
    Race Face X bottom bracket (current pet annoyance)
    gusamc
    avid juicy 3 brakes
    the strange need for every twosser to design a new rear mech hanger
    reinventing the wheel, BB,…..
    Northwind
    QR15. All the stiffness of a QR, all the weight of a 20mm maxle
    Infinite dropout standards
    The Big Ring
    kingkongsfinger – Member
    Girvin flex stems
    Oh hells yes. Doesn’t really do anything, until the elastomer gets slack, which happens pretty much instantly. Then, still doesn’t do anything useful, but does helpfully disconnect the bars from the bike. Oh and all capped off with some nice sharp edges on the back with which to bifurcate your nuts.
    avdave2
    I actually quite liked my Girvin Flex stem.
    My Hite Rite on the other hand was useless because I was(and still am)too light to compress it.
    unklehomered
    Hope QR seat clamp
    none lockon grips
    tiny tiny hex screws…
    sambob
    Crank Brothers cheap pedals
    Cleat bolts made of cheese
    Anything made by Clarks
    james
    erm. maybe non-black chilli conti tyres
    pumps that use the cam locking lever arrangement. why not just screw on ala zefal/leyzyne?
    ‘power buldge’ rockshox lowers. Once you wear the lower bushes, you have to get new lowers
    Quite a lot up there Im questioning
    shimano external BB for one, aside from Stainless steel/ceramic vwhat BB standard do you prefer? (square taper for me is flexy and is too easy to round out the squares)
    PrinceJohn
    Hollowtech II bottom brackets
    Tioga Tyres
    Tapered Headtubes
    buzz-lightyear
    Giant Contact dropper seatpost- either stuck up or stuck down
    Isis Bb of any sort
    Conti mountain king 1 tyres
    shortcut
    26 inch wheels
    Crank Bros pedals
    Avid brakes
    mtbfix
    Conti Vapor tyres on the front
    Any QR not made by Shimano
    GXP BBs
    Slacken the seat clamp. 8nm does the trick.
    gee
    Crank brothers products
    Flippyshifters
    Cheap steel suspension forks on entry level bikes
    tomhoward
    Tioga factory dh tyres
    Gripshift
    Quill stems
    climbingkev
    1. Continental Verticals
    2. Lezyne leaky bladder
    3. DT Swiss rear maxle
    bigblackshed
    Anything with Truvativ written on it.
    munkyboy
    3wheel size standards
    Press fit bottom brackets
    British summers
    tazzymtb
    avid disk brakes
    anything by crank bros
    U brakes
    RustySpanner
    Rear suspension.
    High Rollers.
    Lock on Grips.
    whatgoesup
    Pressfit bottom brackets
    beanieripper
    avid brakes
    bb30
    cr@p bros stuff
    farmerjohn… do you mean the avid thingamajig thingy?
    TurnerGuy
    Rear suspension.
    Cable Disc Brakes
    cakefacesmallblock
    Cheap crap made-of-cheese bolts n screws ( Shimano top o the list).
    Cable brakes, disc or rim.
    Leaky bite valves.
    AlexSimon
    Most own-brand hubs found on low and middle-range bikes.
    (yet they still manage an XT rear mech sigh).
    Carbon seatposts
    Hope Q/Rs
    Non-aheadset Headsets
    wisepranker
    Anything by Truvativ
    Anything by SRAM
    Avid brakes
    Can you guess what bits I’ve been having problems with lately!
    CHB
    Coda bike bits fitted to canondale bikes.
    No brand suspension forks ( with xfusion and rst nearly as bad)
    Hayes el camino brakes: noisy, rough and rusty bolts.
    Neil-F
    “suspension” forks on cheap bikes
    5 tens
    Truvativ cranks
    CaptainFlashheart
    Integrated shifters/brakes, especially the “push-push” trash.
    Grrrrrrrrrr
    And this, silly, silly thing;
    PJM1974
    Ooh look! Someone has come up with a new fork steerer standard! Yay!
    35lb all mountain bikes
    142mm spaced rear axles…why?
    alex222
    sram groupset
    avid brakes
    nicolai frames
    Junkyard
    External BB though the Hope one is better
    Changing/conflicting standards – forks, seatposts, bars etc WHY just all do the same
    Fox service intervals for forks
    Tom-B
    Avid Juicy 3’s
    Sram PC7X chains
    Rockshox Tora’s
The topic ‘Bottom 3 mtbing products’ is closed to new replies.
