So I got unlucky with a second hand stumpy frame. The seller told me it had all new bearings which turned out to be untrue. They eventually agreed to pay £50 back to cover new ones which I fitted myself which was a total pain.
Unfortunately the rear dropout bearings on one side were seized solid and must have been rotating in the frame instead. This has slightly enlarged the press-fit socket in the frame which meant I could pop the new bearing in by hand with no tool required. I measured the socket and it is slightly out of round. I have ridden the bike like this for a few months but it is now loosening up and needs sorting.
A new seatstay is £200 from Specialized so don’t really want to resort to that if possible. Another idea I had was to find a machinist who could bore the socket out. This could then wither fit a larger bearing size or else shim it back down to fit the current size. Could this work? If so, can anyone recommend me a place to get it done? Ideally in London area!
Cheers!
Dan
