Hold onto your hats…. this is going to be dull.
I need to keep a fair amount of paperwork around the house as I’m self employed and my work is quite spend-heavy so I have to file away about £80k – £100k worth of receipts every year.
A Foolscap Folder / Document wallet holds about a financial-quarters-worth of receipts. Each project generates a folder-worth of contracts, release forms and other notes too. I like using document wallets as they travel well in my bag and I can write pertinent notes on the outside of them for quick reference and the contents is usually made up of lots of single sheets and small documents, and in the case of receipts – lots of different paper sizes.
A Foolscap Box File usually just about holds a years worth of folders, and means everything can stand up on a shelf rather than sprawl on a desk. But it holds them badly – you have to squash the folders in and in a while the boxes start to burst, and won’t stay closed properly (in fact pretty much the first thing that happens is the little closer tab pops off when you put the folders in).
First.World.Problem.
I quite like the folders, I can write a lot of pertinent info about the contents on the outside of them. I quite like the boxes because they stand on the shortest end and are the most space efficient way if storing loose paper. I like that both the folders and the boxes are cheap and I can buy them in the local supermarket. What I don’t like is they just don’t quite work together.
So, stationary fiends… Is there a source of slightly smaller document wallets or slightly larger box files? Or just a better solution all in.
And more importantly… can we turn this into an argument?
