Viewing 3 posts - 1 through 3 (of 3 total)
  • Bonty rims tubeless with tape
  • Clink
    Anyone gone away from the bonty rims strips and used tape instead? The bonty rim strips create a good seal, but I find every time I remove a tyre they are a bugger to get off as the the tyre bead gets caught between the strip and the rim. If so any tips?
    RickSpangle
    I converted 2 sets of bonty rims before Xmas….. went ghetto with proper gorilla tape….you tube is your friend..
    One set used bonty tubeless values other set used stans. Both used stans fluid. Using non tubeless tyres on both fronts and tubeless ready on the rears
    Not had any flats or burps. Went up a dream. Have changed tyres a few times too and not had to remove tape or owt..
    Clink
    sounds good, ta
The topic ‘Bonty rims tubeless with tape’ is closed to new replies.
