Lets re -cap
You bought a TLR wheelset and didint buy the manufacturer approved sealing system .
You then tried to use a genereic aftermarket system that is designed to work for most wheel designs OK but maybe not brilliantly.
The selotape system will probably be fine for 8 out of 10 cats wheels , but didnt work so well with the Bontys.
So rather than say OK , I will use something called Google and see if there are any reveiws on The Bontrgaer TLR rimstrips its all abig hoo haaa all on STW.
Just do what I did , spend a few ££ and buy the correct rimstrip. When they arrive you will look at them and think ….’They cost how much for a strip of hard plastic’, you might even post on the stw about how crap they are.
If you get round to fitting them you will probably think ‘ these will never seal , they arent rubbery enough to be air tight ‘
Then you will be pleasantly surprised
The Bonty rimstrips are thick and chunky with grooves specifically shaped for the spoke bed. They stretch round just enough and pop into the slot with a snap.
Even annoying Schwalbes pop up and seal with a trackpump , although 60 – 70 psi is sometimes needed to ping the bead .
As we once got in a entire box of Christmas Crackers , every single joke was ” It is often better economy to but better quality”
