We have a Boilermate 2000 connected to an Ideal Standard 30 boiler. We are having problems getting the central heating to work.
The timer tells the heating to come on. The boiler fires up but after about 2 mins shuts down again. Then we get a serious of whoomfing noises from the boiler along with the ignition clicks. It’s as the boiler is trying to re-fire but fails to ignite. If we turn the thermstat right off the boiler then fires, but no heating.
I suspect the problem occurs when the boiler tries to heat the hot (tap)water when the heating is on. We can sometimes get the heating to work for a while, but the fault seems to be getting worse.
Googling has brought up lots of problems with Boilermates. But I cannot find anything on this specific problem. It isn’t the timer as tried both the original pin timer and a new digital timer.
Any suggestions before I call a plumber?
