Stoner Sr’s oil boiler has given up.
They have an oil Aga with a back boiler, with an additional Oil boiler used for top up in winter and DHW when the Aga is off in summer.
The old boiler was sized at 19kW, which seems small if it were the sole heating source for DHW & CH, but obviously it never gets used as sole DHW & CH as the Aga is always on in winter.
Is there any reason to go for a substantially larger boiler than the old one? Im thinking not really as at 19kW it all seemed to work OK.
As a secondary Qu, the boiler was located next to the Aga. It might be an idea to move it to a wall mounted position in the kitchen, again not far from oil supply, but more usefully right next to an external wall for a balanced flue outlet. Are there such things as wall-mounted oil (noncombi) boilers around 20Kw?
