Hi,
Our Glow Worm 30sxi wouldn’t fire up tonight with the pressure reading 2.0 bar.
If I open the drain valve in the garage and let some water out, the pressure will drop to 1.2 but as soon as I shut the valve it goes up to 1.8, still too much to fire (?).
I can turn the water off after opening the valve and pressure will drop to 0.5 but again as soon again the valve is closed and water back on its back up to 1.8.
I’ve tried various combinations of the above to try and ‘jump start’ it but no joy.
So, any other things to try or if its knackered what might it be and is it a diy job?
Many thanks
Simon
