I bought my first house in November, in which there was an oil fired Worcester Bosch Combi boiler of indeterminate age. The boiler seemed to be working fine when we moved in, but as a precaution, I had it serviced in early December as it seemed to smell a bit rich when burning. The engineer confirmed that the boiler had, in all likelihood, not been service for a good while as it was burning very inefficiently. After the service, the boiler seems to have has been working much better, and burning far less oil.
Two weekends ago, I bled the bathroom radiator as it was only getting hot about a 1/3rd of the way up. I topped up the pressure in the boiler (1.5bar) and away we went. Since this point, the boiler has been losing pressure over the day to around 0.8bar at which point the thermal cutoff activates.
Upon inspection, I’ve noticed water at the rear of the boiler. Further inspection (panels off) revealed that the insulation around the heatslave tank was sopping wet, and that the upper portion of the tank is HEAVILY (like 3mm thick sections flaking off) corroded.
Has anyone had a similar fault and does anyone know if it’s economically viable to fix?
