Body Fat Measuremen...
[Closed] Body Fat Measurement - US Naval Method?
[#3449072]
[url= http://www.calculator.net/body-fat-calculator.html?ctype=standard&csex=m&cheightfeet=5&cheightinch=10&cneckfeet=1&cneckinch=3.5&cwaistfeet=2&cwaistinch=7.75&chipfeet=3&chipinch=2.5&cheightmeter=180&cneckmeter=50&cwaistmeter=90&chipmeter=90&x=43&y=18 ]Anyone tried this?[/url]
Bought 'Racing Weight' yesterday and know the scales I own are rubbish.... your thoughts please?
Posted : 11/12/2011 10:18 am
Must be wrong 😉 I'm 6ft 4 and still 24 stone and apparently im in the acceptable range!
Posted : 11/12/2011 10:27 am
Just put my details in to Navy website and fig comes out lower than on my scales by 2%.
Both systems based on some sort of algorithm, but at least the scales include some form of measurement before the calculation - nither is perfect.
As with all these things, trend is more important than which number you hit, so if by measuring with whichever method, the trend is going in the direction you want, then it's right.
Posted : 11/12/2011 10:28 am
16% according to this. Tanita scales say 23%. Skinfold says 19%. I think I like this method !
Posted : 11/12/2011 10:30 am
lucien - I would argue that a tape measure gives you some form of measurement.
Try standing on your bodyfat scales with a cast iron weight and see what happens to your bodyfat %...
Posted : 11/12/2011 10:37 am
12,6%, happy but could do better.
I'm not sure if any method is going to be accurate, so, like flap_jack, just pick the result that makes you happy.
[img] http://www.smileys4me.com/getsmiley.php?show=2143 [/img]
Posted : 11/12/2011 10:41 am
8% using this method. Scales say 5.9%.
5'11'' and 62kg.
Posted : 11/12/2011 10:42 am
Flaperon - do your scales have an 'athlete' mode?
Don - can you see your abs? It's about progress though isn't it... and finding my racing weight 🙂
Posted : 11/12/2011 10:44 am
From other tests I would have said I was 7% +/- 2% as no test is that accurate.
That Navy link has me at 7.4% so it seems to be reasonably accurate.
Though an inch either way on the waist and hip account for a shift of 2% so it is very reliant on taking the measurements in the correct place.
Posted : 11/12/2011 10:45 am
This is one of the questions I've maintained regarding weight loss and various claims made, no abs to be seen at this stage. So when people mention losing a couple of kilos and are able to see abs forming, I have to have my doubts. But then again I'm never going to be bodybuilder muscular.
My objective is to have no visible fat, and the blob sitting on the gut must go.
Posted : 11/12/2011 10:49 am
TSY - yes, in athlete mode as otherwise they reckons I'm 30% body fat...
Posted : 11/12/2011 10:51 am
HAHA... from your measurements I'm guessing that would be impossible.
I think I need to try some with an athlete mode.
Posted : 11/12/2011 10:54 am
 Keva
Results:
body fat = 11.5%
US units metric units other units
sex male
height 5feet 4inches
neck 0feet 15inches
waist 0feet 30inches
hip 0feet 35inches
Posted : 11/12/2011 11:02 am
TSY - the book says to use it if resting heart rate below 60 and more than 5 hours of "vigorous exercise" a week.
Posted : 11/12/2011 11:06 am
TSY - As long as you did this every time, and the trend was going in the direction you wanted, it would be a reliable form of measurement.
FWIW my Tanita scales on athlete mode have my body fat at 9.6% in the morning and <8% in the evenings, depending on hydration and how much I have ridden that day
Posted : 11/12/2011 11:55 am
My Mum thinks I look ill = racing weight
Posted : 11/12/2011 12:14 pm
 ps44
Last time I had this measured I was borderline malnourished using caliper/skinfold and borderline obese using height and weight. Must be about right then 😉
Posted : 11/12/2011 1:29 pm
'race weight' ? WTF ?
Are there races for different weight classes now ?
Get off the scales and on the bike and aim for maximum SPEED.
Posted : 11/12/2011 2:00 pm
flap_jack - you forget that you already posted your flabby stats above or something?
Posted : 11/12/2011 2:04 pm
13% but I am a fatty at the moment, haven't been riding anywhere near enough and have been eating mountains of filth whilst working silly hours. It'll be back to normal in the new year 🙁
Posted : 11/12/2011 2:11 pm
Indeedy.
I have recently done a Personal Trainer course so I know the 'measurements' at the moment. 'Measurements' in quotes because all these methods are approximations. I prefer the 'if you can see your abs and the split in your biceps then you're under 10%' approximation. Because that gives me an answer I like even better.
When I train for bike racing I won't get on the scales, I closely monitor the power meter on the turbo or on the bike. And do geeky graphs etc (which probably don't help either).
I suppose the important point is that if you think your monitoring will do some good, by placebo effect it probably will. And for that reason it may be worth doing. I'd just rather do the stuff that I think monitors the results that may be transferable to the goal (more speed = winning races).
I've also found I'm fastest running when thinnest, but fast cycling seems (in my case) to need a couple of extra fat kilos...
Posted : 11/12/2011 2:16 pm
flap_jack, placebo effect... 😆
Try reading the book, eh? You might learn something... like about power to weight ratios...
Posted : 11/12/2011 2:20 pm
Maybe I'm more aerodynamic with those fat kilos 🙂 Power to weight ain't everything - although if you think it is, then by placebo effect you'll do better...
Posted : 11/12/2011 2:24 pm
If I bump this will Solo see it and tell me whether I'm allowed milk after exercise on the iDiet?
Posted : 12/12/2011 9:37 am
Yet two posts up you're making out knowing your weight is a waste of time.
Make your mind up. 😕
Posted : 12/12/2011 9:46 am
phil.w - specifically they're fat kilos too.
Posted : 12/12/2011 9:48 am
iDave - Member
ha ha.... and starts bringing cakes round 😆
🙂 I missed that.
Have you finished the book yet. What did you think?
Posted : 12/12/2011 9:55 am
I've not finished it yet, but I'm finding it a good read so far. Haven't really got into the key sections...
It's sort of confirming my theory that for an ideal endurance build I need to lose a bit of lean body weight, or become a cross country skier. 😀
Posted : 12/12/2011 10:02 am
+1 getting grief of mother and 2 grannies here.
Result - Athlete 13%
179cm and 76kg/12st - compared to 15stone this time last year.
Posted : 12/12/2011 11:00 am
In other fitness news, I ran 6.1 miles last night with no hurting tendons and completely relaxed and comfortable the whole time. I still don't look ripped though so I suppose I'm a failure.
Posted : 12/12/2011 11:20 am
Well done Molly... what pace?
Also, can you answer my milk question?
Posted : 12/12/2011 11:21 am
Well the 4HB version of iDave's diet tells you to GOMAD to put weight on, i.e. a litre of milk, 4 times a day, and be super careful about what else you eat to avoid putting fat on at the same time. The implication being that you'll put on muscle so fast a bit of added fat will be easier to get rid of at a later date than to try and put on the same lean muscle slowly.
I drank shedloads of milk while I was off the bike with a knee injury for 2 years at uni, that combined with swimming sessions twice a day meant I was pretty muscly, but also had a bit of a belly, but wasnt planning it as a diet so ate lots of harribo and pasta as well.
Posted : 12/12/2011 11:36 am
Congrats, that's almost a 10k nailed.
Oh, and apart from sprinters, most runners don't really look ripped.
Posted : 12/12/2011 11:40 am
Jamie - did you watch the world cross country racing yesterday... even the women were ripped... well lean as hell!
Posted : 12/12/2011 11:41 am
TSY - Can't say I did. As always, I am always ready to be corrected.
Posted : 12/12/2011 11:55 am
I know what you mean about the sprinters BTW, just looking at some of the distance runners... they're not far off skeletal...
Posted : 12/12/2011 11:58 am
The few races I have done, just 1/2 marathons and the like, you see this guys who look like they should be admitted into hospital as they look so emaciated......then they blast past you as if you were not there*
*as most people do to me.
Posted : 12/12/2011 12:07 pm
Your not exactly slow though Jamie.
Perhaps you just need to get 'the look'?
Posted : 12/12/2011 12:12 pm
I'm firmly mid pack, TSY.
The thing is, I could get 'the look' if I it wasn't for one thing.
I. LOVE. FOOD.
Mostly cakes/chocolate and chips.
...I am going to restart weight training next year, so maybe that will help.
Posted : 12/12/2011 12:15 pm
Me too.
The good lady wants to iDiet and want me to do it too. She's not allowing my hybird version that I've been doing so all the Xmas chocolates sat on the desk opposite me are staying there until Friday.
Posted : 12/12/2011 12:20 pm
What is the Hybrid Version™?
Posted : 12/12/2011 12:23 pm
DEXA
do you have one LabMonkey?
Posted : 12/12/2011 12:24 pm
Ha, it's my own version Jamie... it'll cost you..
Or you could just allow Dairy and Fruit and cheat every 3 - 4 days?
phil.w +1
Posted : 12/12/2011 12:26 pm
