Hello everybody. I have found this issue for other forks, but not this one.
Anyway, its banging pretty hard on top out when rebounding. My understanding based on reading is that this is a problem and not normal. if its not a problem i will ignore it.
I bought a used surly ICT with the rock shox bluto 100mm already on it, the bike is pretty much unridden, but while the fork looks fresh the PO said he got it used, so its hard to say…
it is possible it had a remote on it that the PO yanked at sale, i kinda thought i saw one in the original ad.
I have not ridden it much, is it possible it just needs to cycle more oil in it?
If i have a chance to get it out tomorrow i will cycle it to full compression 20-30 times or so with it dialed to soft…
I Hardly have time to ride, let alone mess with the fork right now. Am i hurting it riding it like this, or should i ignore it till i have time in the winter?
I could swap the stock fork on, i probably will be doing that anyway for winter…
what should i check? I am very mechanically inclined but have not really had mtb shocks apart before. I did find the manual here https://sram-cdn-pull-zone-gsdesign.netdna-ssl.com/cdn/farfuture/sD7UES6538SVHnYz4fQo6JrY5ZLFBGD3jkHkB31DcZU/mtime:1490203293/sites/default/files/techdocs/gen.0000000005114_rev_c_2017-2018_reba_bluto.pdf
…but would love to know if this is normal for the shock before i start hunting down something that is not actually an issue.
I am probably going to put a cold weather kit in once i pull it off the bike anyhow.
thanks, any input is appreciated!
