We have it. It’s very good.
I prefer the vents to radiators. It’s instant heat and if you have the control system which monitors the heat decay in the house it gives a very constant heat (rather than on/off all the time).
Our heater unit gave up the ghost last year, and it was very expensive to replace, but I’d rather have the warm air than the wet radiator equivalent.
My main disappointment is that the timer aspect of the control means there’s nothing very clever about when the system switches on/off and setting different temperatures for different times of the day.
EDIT:
Plus 1 for turboferret – you need to look after the system.
Other advantages: if you have an electrostatic filter, your air is cleaned 6 times an hour (or something). My asthma is 1000 times better for it.
Anecdotally, most people’s gas usage is 30-40% hot water, 60-70% space heating. Ours is opposite – 60% of our gas usage is water heating (hence me having quotes for solar thermal 😉 )
