Viewing 10 posts - 1 through 10 (of 10 total)
  • Block paving brick disolved?
  • notsospeedydaz
    Hi all I got a bit of a strange one. Coming in today noticed a bit of what looked like mud on the driveway went to scrap it off and it looks like some of the block has dissolved? The hole looks about the size of a tomato if I removed all the mud like stuff from it, no other blocks affected
    Not aware that I have spilt anything on the drive always reverse on the drive so its not at the engine end if you know what I mean
    Ive tried looking on the web but even google doesn’t know the answer
    lemonysam
    The cat hasn’t bought anything in lately has it?
    wiggles
    Deadly acid bird shit
    wrightyson
    Sometimes you get the odd pavior with a larger pebble in from the actual concrete mix, this will basically have popped out after frost thaw, frost thaw etc
    wrightyson
    And alien blood of course…
    ThePinkster
    You’ve not noticed any issues with your brakes recently have you?
    slowoldgit
    Presumably a muddy lump within the aggregate just gave up the struggle against rain and frost.
    footflaps
    I prefer the Alien blood explanation.
    mark90
    You sure there’s no possibility of battery acid? Where I used to always park my camper van in the same place on my drive one of the blocks dissolved underneath where the leisure battery drain tube came out.
    notsospeedydaz
    Not aware of dropping any acid from alien blood or batteries. I did change the rear brake pads on the van a few months back but there was no fluid leakage just wound the pistons back
The topic ‘Block paving brick disolved?’ is closed to new replies.
