Need to re-hang some plywood wings (aka doors) on my horsebox. Previously they were fixed with big screws that either snap or loosen.
I got myself a rivnut tool which is perfect for one side which is straight into steel box section, however I didn’t realise that the other side has 12/18mm ply between the plastic wall covering and the box section.
So having drilled out 10mm holes through the wood and into the box section, I quickly realised the rivnuts are useless as they are too short. Even if I enlarged the hole in the ply to set the rivnut against the steel, I still wouldn’t be able to get the rivnut tool in there due to its size.
The perfect solution seems to be a blind bolt by http://www.blindbolt.co.uk but there are not many stockists and even ebay drew a blank.
Screwfix do some hollow wall anchors that might do the trick, has anyone used them? Unfortunately they only sell up to M6 and I really need M8 size. http://www.screwfix.com/p/rawlplug-intersets-m6-x-37mm-pack-of-20/40813
