Viewing 4 posts - 1 through 4 (of 4 total)
  • Bleeding reverbs!!
  • ononeorange
    Mrs o’s reverb keeps getting stuck despite several bleeds. I spotted fluid leaking from the rear connection last night which explains it.
    The rockshox video suggests replacing the barb if I cut the hose – do I really need to and if so where to obtain a new barb from? Can I just cut it, re-insert, tighten and hope?
    honourablegeorge
    My remote lever just unscrewed from the hose, then when I cut it screwed back in – the barb is part of the lever.
    ononeorange
    Cheers – it’s the one under the saddle – is that essentially the same?
    honourablegeorge
    Ah, that end may well be different.
The topic ‘Bleeding reverbs!!’ is closed to new replies.
