Viewing 14 posts - 1 through 14 (of 14 total)
  • Bleeding New Shimano Brakes – Easy?
  • MRanger156
    Got some new Saint brakes but the hoses are too long. If/when I cut them down how easy is it to bleed the system?
    Is it possible to shorten the lever throw through the bleeding process?
    PeterPoddy
    Can be done if you're careful, but they are very easy to bleed, no special kit required. 🙂
    simonfbarnes
    easiest I've ever done
    PeterPoddy
    I'd second that, actually.
    (Magura are just as easy, but require syringes and the like, so a bit more faff)
    MRanger156
    So is buying the bleed kit a waste of £50?
    younggeoff
    easiest I've ever bleed took 5 minutes literally.
    Take reservoir cover and diaphram off, get a syringe with a small tube put over bleed nipple on the caliper, open bleed nipple suck all the old fluid out with syringe. Fill syringe with new fluid, attach to bleed nipple, force fluid back up to the lever from the caliper, close bleed nipple. Top up reservoir, roll the diaphram back over, refit resevoir cover. Job done 🙂
    MulletusMaximus
    Small tube be bought from pets at home/ pet smart in the fish section. Fits perfectly over the bleed nipple. Costs about £1. 🙂
    antigee
    not sure about saints bled some new slx brakes last week after cutting down hoses and used shimano mineral oil that comes with a tube and bag that fit the bleed nozzle on the caliper which for a piece of plastic tube isn't cheap (£10 with oil) but it works – there is a fact sheet on shimano web site
    http://techdocs.shimano.com/techdocs/blevel.jsp;jsessionid=k1WSKBcGj2vmyQHLlN9LHcGKH62zs4d8ggtS3HWdnTj971hz4m4J!-545645630?ASSORTMENT%3C%3East_id=1408474395181679&FOLDER%3C%3Efolder_id=2534374302059413&bmUID=1254218918163
    click on for bleeding
    also there is a fact sheet i can't find that says if you are brilliant and got five thumbs and there is a Z in the month you can cut them ok without bleeding
    lever movement – noticably less after bleeding – think seen comment on here that as they come not that well bled
    edit i guess the big bonus of using a syringe and back filling is you don't have to remove calliper and any ties – shimano simple method relies on gravity and prayer
    rootes1
    also make sure that the caliper pistons are as far into their bores as possible and keep them there – use the shimano block or a little block of wood – help stop air pockets being created in the piston bores
    noidea
    Done my saints the way Younggeoff describes after shortening the hoses,very easy and a pleasure to do after mucking around with Avid's.
    jimbobrighton
    can be done without any of the faff.
    wheel out
    leave pads in
    put screwdriver/thin flat thing in between pads
    squeeze pads together
    take off hose at lever end
    cut to length
    install new olive, being careful not to spill fluid out of hose
    put hose back on lever
    take off reservoir cap
    push pads apart, pushing fluid back through the hose and into the piston – you should see a few small bubbles pop up through the reservoir.
    top up reservoir, put diaphragm back on, squeeze brakes
    done. no ttubes, no syringes virtually no oil needed either.
    I've done it on saints before and it works a treat.
    take hose off lever end
    cut
    jimbobrighton
    ignore the last two lines of previous post. I'm a muppet (but one that can bleed brakes) 🙂
    MRanger156
    So do you suck ALL the oil out from the calliper end? Would this not get air into the system that might not be flushed out when you refill?
    thepurist
    Might try that technique Younggeoff – I've got 2 sets of XTs, the ones on my FS are rock solid but the ones on my hardtail have always been a bit squishy, despite both sets being built up and bled by me using the same (shimano's) method.
The topic ‘Bleeding New Shimano Brakes – Easy?’ is closed to new replies.
