benpinnick – Member
Reverb syringes work well
Bloody awful for bleeding Reverbs though. They leak!
Got two sets and all four syringes leak out of the hose ends. That’s with the Reverb fluid (2.5wt stuff).
Old Avid kid for bleeding Avid dot 5.1 stuff and never had a problem with that.
Is it the syringes or the different oil with the Reverb that makes it more likely to leak out the ends? (thinner oil than dot stuff?)
Got syringes that came from TF Tuned also for doing fork lowers, but those are rubbish too. The rubber bit inside got swollen, stuck and ended up pulling it right out and now it won’t go back in. Didn’t use it for brakes, just for the forks.
