- This topic has 104 replies, 33 voices, and was last updated 11 years ago by lasty.
Blanket 20mph speed limit for Brighton
MrAgreeableFull Member
Here:
St Helens KSIs rose from 43 in 2010 to 73 in 2011
Stoke on Trent KSIs rose from 45 in 2010 to 71 in 2011
Portsmouth KSIs rose from 92 in 2010 to 143 2011
Coventry KSIs rose from 90 in 2010 to 137 2011
These were also the councils with the biggest increases/decreases in the KSI rate per billion vehicle mile.
So bugger all to do with 20 mph zones, and part of what could well be a wider national trend.
sTroll on, eh?
ahwilesFree Memberthanks for those very worrying numbers Mr A.
(although it seems the national trend is good, there are a few ‘hotspots’)
sbobFree MemberThe national trend was a 2% increase, as already stated on this thread (possibly attributed to weather).
sbobFree Membermiketually – Member
Increased safety for cyclists, as a percentage or per mile or whatever. But the number of accidents overall could still increase as you’re still moving people out of cars and onto bikes.
Surely my bold is the only important metric?
Of course, 1 million cyclists will have more accidents than 100, but I’m certain (from many sources found in one of the helmet threads) that an increase in cycling leads to an increase in safety.sbobFree MemberGrahamS – Member
Yep fraid so. Road injury rates are higher on foot or bikes than they are in cars – so getting some people out of cars can mean an increase in injuries.
But the more cyclists, the lower that injury rate is, and fewer cars surely means fewer car crashes?
I’m sure you’re not, but it sounds like you two are trying to argue against cycling as a safe mode of transport!
MrAgreeableFull MemberThe benefits of “safety in numbers” are actually a lot less clear than the CTC et al would like to you to think.
http://crapwalthamforest.blogspot.co.uk/2011/02/what-wont-bring-about-mass-cycling-6.html
sbobFree MemberMr Agreeable – Member
If you look at a country like the UK, where there hasn’t been a big enough increase or decrease in cycling to be statistically significant, then yes, it isn’t that clear cut.
Ignoring bullshit blogs for a second though, and looking at the wealth of statistical data available using countries all over the world, it would certainly appear that increased cycling = increased safety.
Of all the places where I had imagined I would have to defend cycling as a safe and beneficial mode of transport, this wasn’t one of them. 🙁
buzz-lightyearFree MemberIt’s going to be hard for cyclists to stick to that speed limit
MrAgreeableFull MemberIncreased cycling = increased safety? Or does increased safety = increased cycling? They’re not the same thing.
Interesting that you mention other countries with high levels of cycling. In the Netherlands they have a default speed limit of 30 km/h in residential areas. Same in Germany. Just sayin’.
sbobFree MemberI live on a 30mph road where everyone does 15-20 mph.
OMFG PEOPLE ARE THINKING FOR THEMSELVES!!!
What is it about commies (that is, the general STW pop.) always wanting to dictate and be dictated to? 😕
So you think an increase an cycling would decrease safety?
Or do you not know what you think?MrAgreeableFull MemberYou can’t be prosecuted for exceeding the speed limit as a cyclist, only for “furious cycling”.
http://www.astounding.org.uk/ian/cyclelaw/speed_limits.html
I’m not so sure, all that willywaving must create substantial amounts of drag.
simons_nicolai-ukFree Member2010 – 92 KSI
2011 – 143 KSICare to dispute that?
The question is more complex. Cyclists KSI’s are up in London but # of journeys is up as well which *could* explain it. The problem is that actually the KSI’s per mile travelled seem to be increasing – ergo London’s streets are becoming more dangerous.
You can easily reduce pedestrian injuries to zero by removing peds from the roads (Motorways are very ‘safe’ places for pedestrians based on the stats). There is a large body of evidence that suggests the reason for improvements in ‘road safety’ over decades is that removing peds from the roads is precisely what we’ve done – kids don’t play outside any more so they dont get run over. That’s not really progress.
Reducing road speeds, encouraging peds back onto the streets may well increase KSI’s in the short term but it’s a move in the right direction. Surely the answer is to do more to remove the danger, not to remove the people.
correlation =! causation
Alternatively, places where it is safe and pleasant to cycle have high rates of cycling. Which seems more likely?
but why have this argument here – it’s been comprehensively shot down in flames elsewhere. There is no ‘safety in numbers‘ effect on the roads – it’s wishful thinking, not a strategy for mass cycling.
Read AsEasyAsRidingABike
sbobFree MemberI’m struggling to understand how having less motorists and more cyclists will maintain or decrease road safety. 😕
ETA: it’s ok; I’ve read your link and it agrees with me:
“Cycling gets safer the more people do it.”
I think this is generally true.
andytherocketeerFull MemberIn the Netherlands they have a default speed limit of 30 km/h in residential areas. Same in Germany. Just sayin’.
AND just to mix it up a bit… also legal for bikes to go the wrong way on one-way streets. Oh and just to mix it up a little bit more (and as I’ve mentioned many times before), also green traffic light for motorised traffic turning right across ped/cycle crossings that also have a green light to cross/proceed.
My street is a one way street, 30kph limit, that allows both ways for bikes 🙂
D0NKFull Membercorrelation =! causation
once lots of people are cycling (if!) we stop being an out group and are treated with more respect and safety on the roads by most other road users, serious bike/vehicle interactions should go down, total number of minor falling off bike accidents will obviously rise but increase in nation’s health should outweigh all that.
Safety in numbers sounds promising but it’ll be a long time and an order of magnitude of numbers before its felt. Needs a societal shift and I’m doubtful it will ever happen.
simons_nicolai-ukFree MemberSafety in numbers sounds promising
I’m assuming you didn’t actually bother clicking through the links?
sbobFree Membersimons_nicolai-uk – Member
I did.
I like the bit where he generally agrees that increased cycling = increased safety.Hang on a minute, did you read the link? 🙂
simons_nicolai-ukFree MemberWithout reproducing the whole ‘swimming with sharks’ piece I’ve picked out a few key paragraphs for you. Which bit are you referring to?
“Those who think that the best way to create safer cycling is just to get more people cycling should take a long hard look at this graph, because frankly it’s a complete mess, that shows no clear relationship at all between the amount of cycling, and relative safety”
“In other words, according to Jacobsen, the reason cycling has become safer is not because of changes to the physical environment; rather, the “more plausible explanation” is that drivers are behaving differently now that they are surrounded by more cyclists. I’ll leave you to judge whether that is indeed more plausible; what is interesting is that this explanation of improved driver behaviour as a consequence of being surrounded by more walkers and cyclists is only a hypothesis. It is not substantiated by Jacobsen”
“the causal relationship posited …simply isn’t substantiated….we still don’t have any evidence that driver behaviour is actually modified or improved by the presence of more cyclists to the extent that there might be pay-offs in terms of the safety of the latter group”
” In other words, the best evidence suggests that the relationship runs in exactly the opposite direction to that commonly assumed – namely, it is safety that is producing numbers“
“In a paper published in 2009, Rune Elvik argued that a doubling of pedestrian and cyclist volume, with corresponding mode shift away from driving, would not, alone, reduce the KSI burden, and may actually increase it. Indeed, he suggests that, without any change in the environment, it is only when the amount of driving is reduced by 50% (with corresponding mode shift to walking and cycling) that we may see a reduction in the total KSI burden. That is an enormously long way to go by ‘Safety in Numbers’ alone”
‘Safety in Numbers’ is a serious distraction from the actual business of making cycling safer.
sbobFree MemberThe bit I quoted six posts up.
Do you really think that having less motorists and more cyclists will maintain or decrease road safety?simons_nicolai-ukFree MemberIt’s the ‘less motorists’ bit that’s the issue. You need to make a large reduction in motorists numbers – 2009 paper referenced suggests 50%.
A minor reduction in motorists often just leads to higher speeds – London wasn’t actually more pleasant to cycle around during the olympics, nor is it at night, because the remaining vehicles drive faster.
If you can pull that one phrase out from the body of evidence presented you’re obviously a troll. Will walk away.
I’m a troll for quoting your “evidence” (which is in the main opinion. Nothing wrong with that but don’t pretend it’s fact)?
Sounds more like you’ve just embarrassed yourself.
I presume you’ve read the 2009 paper, The non-linearity of risk and the promotion of environmentally sustainable transport?
ahwilesFree Membersimons_nicolai-uk – Member.
you’ve got a point.
my commute is much more pleasant at rush hour, i can just pootle past all the stationary/slow-moving cars.
lastyFree MemberNot interested in statistics to be honest – educating bad drivers MAY be a way forward but dont hold your breath, there will still be the blind granny, the mother bollocking the kids etc etc…
As far as 20mph Brighton goes – Itll just be a case of getting everything in place (signage etc), get the odd few sticking to 20mph, a year or so on make it mandatory then a few bobbies / cameras to add to the council/police coffers.
Politicians never do anything for the good of the community (in my opinion…) unless it involves self promotion or a favour .Call me mr cynical …
The topic ‘Blanket 20mph speed limit for Brighton’ is closed to new replies.
