Viewing 5 posts - 1 through 5 (of 5 total)
  • Blackspire Stinger+SLX BB
  • edinburghbiker
    Hey guys, Does anyone know whether or not a Blackspire Stinger (BB mount) would be compatible with a Shimano slx hollowtech BB. (the one that comes with the slx double with bash)?
    getonyourbike
    Yes
    orangeboy
    Yep all good just remove one spacer from the drive side bb cup
    PJM1974
    Yes. As Orangeboy said – I an SLX double with Stinger and setting up was easy peasy.
    james
    It will fit with the BB, but if you have a 73mm bottom bracket shell AND you want to run a granny ring you’ll probably run into trouble like so:
    Managed to get it going with a grinder reshaping the stingers back plate a bit and another thin BB spacer (making it wider than ideal), but sill got a little chainrub in lower gears
The topic ‘Blackspire Stinger+SLX BB’ is closed to new replies.
