Just fitted one of these whilst changing to 2×9 and something ain’t right.
The shape of the roller has 3 sections – A high, right angled section on the frame side of the roller,
then a lower section, then a ramped (approx 45degree) section going back up again.
In the granny ring it’s fine, the chain sits on the high section on the inside.
But when I change to the middle ring the chain sits at an angle on the right-angled shoulder of the high section. This not only looks weird but it pushes it against the bash and grinds like hell.
If I flip the roller it’s fine, the chain sits on the angled section and doesn’t get pushed as far over.
But it doesn’t look like it’s designed to do that.
Something I’m doing wrong?
This is on a BB30 with spacer removed and 24/34 rings.
cheers
