Droppers are ace. They make some riding a real pleasure, but would you attach something like an Alpkit Koala to one?
Obviously you’d not use the full drop whilst it was on – but what I want to know – would wear and tear bugger the dropper structurally? They’re necessarily smooth things – would the tug/rub of something like that affect the dropper?
Whack a section of pipe lagging foam over the top?
Or I have seen a second cut down seatpost bolted on the rails behind the dropper and mounting the bag to that. If rs still do enduro collars you could use one to let you drop as far as the bag allows.
I tried a beam rack on a Thomson dropper. By the time it was tight enough not to move on rough ground it made the dropper action sticky like a too tight seatclamp .
I heard that too – and that even then they still swing a bit.
Foam/lagging seems favourite. Could get a bit of pool-noodle type stuff and cut it to the exact length that you’d need to form a buffer so when you drop your post you’d know how far down you could go before you’d risk your seat bag hitting the rear wheel.
Wolftooth do a little collar thing that you fit round the top of your seatpost.
I abused 3D printer privileges at work to make my own version of that a while back- it clamps high then has an ‘outer’ tube that stands off the stanchion and fits over the collar so you can support the bag a long way down the post and still drop a decent distance.
All the clamping is done above the strap- I think I still had maybe 75mm of travel, ish. It comes apart in two halves. Still mk1 so held together with zip ties and using a rockshox enduro collar doodad to brace it at the top. Not a peep out of it on the BB200 but I admit I haven’t used it since.
Never tried a koala type saddle pack on a dropper but I can see the issue.
In theory if it stayed still you only really need a collar as wide as the bag strap I’d think – so is the oversize to take up the inevitable movement of the bag strap walking up and down or to prevent the bag crashing into the rear tyre / being buzzed by it?
The height above the strap is where the clamping happens so the post can drop further. The height below is partly to allow some adjustment, partly extended down to overlap the collar of the reverb so that there’s no chance of them catching on each other on compression
Posted 7 years ago
Viewing 14 posts - 1 through 14 (of 14 total)
The topic ‘Bikepacking with a dropper?’ is closed to new replies.
