righty i have a five spot with a 90mm stem and a 456 with a 70mm stem both have exactly the same reach from tip of saddle to bars (same saddles) now the 456 feels much better on the downs and equal on the ups is this due to the short stem ? ie should i stick a 70mm on the turner and slide the seat back or run a shorter total reach .
id like them to feel at least similar but can it be so or is it just a case of completely different bikes feel different even with saddle height and actual reach are the same ?
also for people on here with a few bikes do you set them up with the same reach/saddle heights i use both mine for general stuff so thought same measurements would be good but it appears to not quite work
sorry for going on lol
cheers
