The trek fuel is a great bike and is very capable, more so than its 120mm travel would suggest. I have to ask why you would want to mess with something that’s already one of the best bikes in its class. It isn’t designed for rough DH tracks but is fantastic for flowing single track, I also found it jumps really well and would be happy using it occasionally for that sort of thing as long as the jumps had smooth transitions.
I assume you have the 120mm version, in which case adding longer forks will raise the BB and slacken the seat tube, which will compromise the bikes performance in the areas that it currently excels.
Personally I would fit a pair of 120mm forks with a 15mm axle. You could fit an angleset but I don’t think it needs it.
