Quick question, would you expect your mountain bike to be well balanced or are there too many factors going on for this to happen? Basically I have a new Orbea Rallon which feels very sketchy cornering on the road (seems okish off road). So got home and tried the hands off the bars test and the bike dives to the right. I’ve looked at all the normal suspects, tyres are seated properly, dropped the forks out, headset bearings look fine etc. Not sure what the issue is or if you’d just expect this with mountain bikes or if I got a Monday morning special ?
Previous bike is a Kona process 153 and while it’s not exactly perfect it’s far superior to the Orbea rom a balanced perspective.
Is there anything obvious I should check ? I’m thinking at the moment that I’ve just got a bad frame.
