Mrs NBT curently rides a Turner Flux and loves it. It’s not new but it’s a great bike, currently sporting 3*9 shimano gears, hope brakes, sektors up front.
The wheels (stans on hope pro ii) are getting a bit creaky – could do with new bearings and probably new rims. In reality this probably means selling the current wheels and replacing with new ones 🙂
Due to old injuries, Mrs NBT also struggles with using the front shifter, as her thumb can be stiff and doesn’t always generate enough force to make the shift, especially when the shifting is sticky due to crappy cables
So, my choices are to buy new wheels along with a 1* 11 (or 1*10) groupset, or to look at new bikes
Having chatted to Jackie on yesterday’s pootle, Mrs NBT is now intrigued by the idea of a 29er. I’ve been riding one for some time, however she’s always been reluctant to try them as being “only 5’4″” she feels she’s too small. This notion was dispelled by the fact that Jackie is no taller (indeed possibly shorter) than Mrs NBT, but felt that her riding had been transformed when she moved to a 29er
So, if I were to look a new bikes, what should I be looking at? 29ers are ok, I’ll consider 27.5, but probably not worth a new 26″ bike as the Flux is a damned good frame. Ideally single ring with a WIDE range (Mrs NBT is a frequent user of the little ring), and ideally with a dropper post, or a frame which will take the 30.9 dropped currently in use on the flux (shims are acceptable)
over to you
