mighty impressive tbh …….
reccomended for sure.
most of the bad reviews state its hard to clean – make coffee – rinse out job done ….. the bad reviewers must be leaving it sat and letting the milk go crusty ….
i expected it to foam up then the foam **** off quickly but that doesnt happen , its better foaming than many coffees ive had in supposedly good shops and the foam stays put
only thing ill say is use a stronger coffee than normal . i used taylors ground fairtrade for the first few cups as your supposed to throw them away anyway and its cheaper than the good stuff … of course i did try those cups , they were fine but i put in the columbian ground that was on special in the shop and WOW
and it was only 33 quid not 38 like i thought
