Viewing 11 posts - 1 through 11 (of 11 total)
  • best way to remove bathroom silicone from tiles etc.
  • odannyboy
    need to redo some white silicone on white tiles. i can cut it out with a razor blade but im worried it will make marks on the tiles (from the metal blade) any tips/ideas…
    clubber
    The tiles won't mark – at least, mine didn't
    wwaswas
    silicone killer stuff and then one of those scrapers they sell to get paint off window glass when you've painted the frames that uses a stanley knife blade.
    0303062650
    http://www.google.co.uk/search?q=silicone+eater&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
    nope, tiles shouldn't mark using a razor/stanley blade, unless your tiles are made of green-clay, plastic or rubber?
    Blazin-saddles
    use a very sharp blade and you'll be ok, use it more of a razor than a knife if you get my drift (keep the blade flat)
    matthewjb
    Cut the bulk off and then use silicon remover to tidy up the bits.
    donsimon
    Get the professional tools, if not, as wwaswas says and patience.
    Tiger6791
    Look at this link
    http://www.cornertape.co.uk/products.html
    Click on the 2nd tab / Products.
    You can buy these at Topps Tiles for a couple of quid, and then use Silicone eater on the left over bits.
    I've found that silicone eater doesn't work that well if you don't remove the bulk of it first.
    odannyboy
    tiger have you used that corner tape then?any good?
    Sui
    Blade, silicon eater, and wipe over with white spirit after!!!
    when you reapply FILL UP THE BATH FIRST!!!!!
    edit: if you are doing a bath 🙂
    ps: use just use a wet finger to smooth over with and make sure no hanging "bits" left.
    Tiger6791
    It's a 75% tool, but better than a blade and screwdriver and worth the £10
The topic ‘best way to remove bathroom silicone from tiles etc.’ is closed to new replies.
