- This topic has 65 replies, 34 voices, and was last updated 7 years ago by crashtestmonkey.
Best value trail bike at the moment to replace Specialized Camber Evo 2015
Tom_W1987Free Member
Seriously, go coil and make sure you pack the bearings with plenty of grease.
Tom_W1987Free MemberLearn to do more spannering as well – carrying out a lower fork leg service every 50 hours of riding will mean they stay nicer for longer, wiping the dirt off seals and applying a bit of lube to the stanchions even helps.
A wolftooth stainless steel narrow-wide chainring if you’re running a 1x setup will last much much longer than a standard aluminium one.
Hope brakes are bombproof compared to the rest of the market at the moment – and Hope will even send you some parts for free – so servicing costs may be reduced. Sure, they’re a bit more of an initial outlay – but as long as you’re happy not having the latest gear, they’ll last you a decade.
Run a small fender on the forks all year round, that will save a lot of shit from being thrown onto the stanchions and thus the seals.
Buy deore everything for the drivetrain, except for the shifters if you want it to still feel good quality – I’d say go with XT shifters. For something a bit nicer but on a budget, I’d say deore cassettes, SLX mech and XT/XTR shifters.
Run heavier duty rims if you kill wheels….
Never use alumnium nipples, use brass ones…they last a lot **** longer..
Lots of little things go along way towards making a bike easier to live with. I’ve got over 20 years of mountain biking experience (been doing it since I was very young), most of the costly maintenance comes from people running things that are too lightweight for their intended use – 160mm discs…boiled their brakefluid and destroyed their brakes seals….aluminium nipples used in carbon rims and then people wonder why they get galvanic corrosion….200lb hippos riding on Stans Crest rims for aggressive trail riding and then wondering why they folded a wheel…etc etc
StevelolFree MemberStuff breaks.
I have one bike, a carbon 5010. In the past month I’ve replaced:
Entire drivetrain (everything)
Front tyre
Rear hub bearings
Frame bearings (8)
Fork seals
Rear shock serviced and stanchion replaced.Its frustrating, but that’s mountain biking sometimes. Before this got done I’d not spent much money or time on it other than cleaning, a tyre abd brake bleed in about 18-24 months.
Do the maintenance yourself. I started riding 8 years ago, first thing I did was replace a gear cable and I even got that wrong! Now I can replace bearings, do lower leg and damper services on my Marzocchi forks and build wheelsets.
You’ve either got to be prepared to spend a bit of money, or spend time in learning the maintenance.
I would 2nd the suggestions on coil, hope brakes, packing beatings with grease. Look at an Orange Five if you want minimal frame bearing issues.
idiotdogbrainFree MemberI think what you need is a single pivot Orange 29er with a coil shock, Marzocchi coil forks, cheap 1x drivetrain with a SRAM steel NW chainring and the all-steel Sunrace wide range 10sp cassette. MudHugger guards front and rear and you’re done. Should be able to put that together for your budget I’d say.
tomasoFree MemberLearning to do it yourself is key. It will save you time and money. It can be stressful but then doing preventative maintenance can prevent the stress of your bike having problems before a big ride.
Buy a book like the Park tool maintenance manual and get stuck in.jambalayaFree MemberOnly need a chain a year? You ain’t riding enough
My chains / groupsets seem to last 2 years minimum 😳
My 2006 Hardrock is on the original Deore kit, Surrey Hills for 2 years, loaner bike, daughter and son-in-law commuter, back to loaner and now pretty buggered (wntertaining movement in headset, bb, wheel bearings) !
OP new groupset or min chain and cassette every year, brand new brakes £100 (xt) then oads once twoce a year, suspension picot bearings once a year max. Given your conditions that what you should expect. A new FS around £1500 is going to have cheaper components that don’t last and are harder/more costly to maintain. Thats the whole point of kit like Hope, you pay more updront but it last longer amd is easier to maintain.
One final thought, at £1,500 personally I’d look at a hardtail with better kit on it and imo it would be more suitable given the mud etc. 120-140 travel to handle to rocky descents maybe. Plus spend £200 on a 1-1 session with Jedi (Tony) at UK Bike Skills – THE best money you’ll ever spend on your mtb-ing.
futonrivercrossingFree MemberFully rigid 27+ or 29+/half fat and use 2 or 3 chains in rotation. I like the idea of a stainless narrow wide chainring.
NobeerinthefridgeFree MemberSo is it completely uneconomical to run any FS in Winter in the UK ? (Unless you stick to the drier Trail Centres) ?
I 0nly ride FS (though I have 2) all year round, though I probably ride more in winter tbh, as nice weather means family stuff too.
Keep everything lubed, use a decent lube that doesn’t hold all the gloop – rock n roll blue for me – bearings greased as above too. IMO a GX 1×11 is a great set up for winter, really solid steel cassette.
Keep on top of the maintenance, I quite enjoy an evening servicing forks etc.
There’s a surprise eh? You’ve no time to ride your bike, always on here spouting nonsense.
chiefgrooveguruFull MemberLearn how to pop the seals off your bearings (surprisingly easy with a dental pick) and pack them with marine grease before squeezing the seals back in place. Use Mobil XHP222. With that in them it’s very hard for water to get in so your bearings will last WAY longer.
iaincFull MemberI don’t ride my FS much in winter however my HT is used a couple of times a week, in all weather. 2×10 XT drivetrain lasts about a year. Pads need changed every few months, fork (Reba) goes to TF Tuned annually. Reverb breaks and gets warrantied every 18 months 😀
That’s been the pattern for the 4 yrs of that particular bike and it’s as good as new.
I am considering using FS all the time, as not getting any younger, but do wonder how much work would be involved in maintaining shock and linkages (current Giant Anthem)
Garry_LagerFull Memberiainc – Member
I am considering using FS all the time, as not getting any younger, but do wonder how much work would be involved in maintaining shock and linkages (current Giant Anthem) I got two years out of my anthem linkage. Thought it was basically OK, but on taking the shock out to replace a bushing, couldn’t believe how much movement was in the linkage. Rickety as anything, so had to replace [ten bearings, awkward job first time round].
So I think if you’re predominately just pushing the miles out, then the maestro is fine to run over winter. If you’re descending hard, racing etc, or have low tolerance for flex in a bike, then best to park it up.zippykonaFull MemberIs the anthem bearing swap difficult or just time consuming?
Is there a special tool that makes it a lot easier?Garry_LagerFull MemberIt’s OK – I was doing it first time the night before a race, so it felt like more of a difficult job than it should have done.
You can buy a set of blind bearing pullers, or use a socket set and a vice. There is one particular pair, though, that is hard to manipulate in a vice – the smallest bearing on the top of the seatstay. I had to reach for the hammer in this case.
There was a recent thread on it here and a poster [stoddys] was v helpful in sending through some tips.If I were doing it again, strip the bike down, clear the decks, take my time – I think it would be easy.
NorthwindFull Membertpbiker – Member
Go single pivot to save on bearings if you need a full suss
Nah, don’t, the saving is bugger all. Some badly designed bikes do go through bearings but otherwise, bearings are one of the smallest maintenance costs for a bike.
RamseyNeilFree MemberIf you ride your bike often and all year round it’s not unusual to need bearings changing on an annual basis which can cost upward of £150 , if you also follow manufacturers recommendations you should probably service your shock at the same time which could well cost another £150 so costs are not insignificant .
chiefgrooveguruFull MemberIf you get a bike that uses common bearing sizes and can be relatively easily changed yourself then that can save you a lot on pivot servicing. A set of eight bearings for my Spitfire is under £30, including the marine grease I add to them.
I bought an RRP bearing press and the proper tools for under £100 but you could make your own version with threaded rod and nuts and sockets for a lot less. Makes it an easy job, just a bit time consuming – I’d expect it to take 15 minutes per bearing, so two hours for the lot (starting with a clean bike).
If you ride a lot then sadly you have to either pay someone else or spend time on maintenance – bikes wear out. The mileage relative to maintenance may seem low compared to cars but it isn’t relative to hours of use.
NorthwindFull MemberRamsey Neil – Member
If you’re prepared to pay too much, sure.
NobeerinthefridgeFree MemberMy yeti was bloody expensive for bearings, but it wasn’t 150 quid!
RamseyNeilFree MemberNorthwind – Member
If you ride your bike often and all year round it’s not unusual to need bearings changing on an annual basis which can cost upward of £150If you’re prepared to pay too much, sure.
I know that you can do it yourself and you can get bearings from sources that are cheaper than buying from a bike manufacturer but my comment was really directed at the OP who admits to being not great at doing it himself and the specialized bearing kits are £70 for that bike so that only leaves about £65 labour plus VAT and you have your £150 .
ajantomFull MemberI think if you’re spending 1.6k in a year on maintenance then it’s not the bike’s fault. As was discussed at length on your previous thread your mechanic/s seemed to be taking the piss with costs and replacing stuff that wasn’t needed.
Also, you need to have a look at how you’re riding and treating your kit. Sounds like you’re not doing simple cleaning and maintenance very well.My current fave ride? A Dialled Love Hate single speed. Almost full 2nd hand….£100 frame and headset, £75 suspension forks, 10 year old Middleburn chainset, mismatched wheels from a bike jumble, Deore disc brakes (well abused!) – probably cost £350 all in.
Looks shonky, but runs like a beaut. Very low maintenance costs too!PJM1974Free MemberI’ve been following this thread, along with the sister thread about how much the OP is spending on maintenance.
To be blunt, buying another bike isn’t going to fix those issues. If the OP is constantly handing over money to a “mechanic” then I suspect that is the root of the problem.
The OP also has been very quiet as to whether they’ve contacted Specialized for comment – I’ve owned Specialized bikes for fourteen years, their warranty dept look after you and are more than happy to fix stuff with minimal fuss all round. I’m on Specialized number four and it’s been brilliant.
Something really doesn’t look right about this thread at all…
jambalayaFree MemberMy pulled from the air (or another A-word) rule of thumb is
£1000 budget hardtail
£2000 budget full-suss£1500 is mid-range but as I said given OPs experience and conditions I’d choose a hardtail with better components especially BB and wheel hubs. As above Deore cassette/chain/brakes are just fine amd who needs lightweight kit in a bog !
brassneckFull MemberA ss cost me about £200 all in, though I had some 26″ wheels.
Wiltshire mud destroys bikes, you just learn to work around it.shortcutFull MemberI can’t think of much to add.
Dragging a decent mtb through seven sorts of rubbish on a regular basis will mean stuff breaks. I too have a 2015 Camber Evo. This has been generally reliable in my view but has very few original items, my forks are currently in need of replacement, dropper post is still working, cranks and brakes are original.
I am on probably 3rd or 4th drive train, 3rd set of frame bearings, 4th bottom bracket, second set of wheels, you get the picture.
The bike has not had an easy life, BC Bike Race, various xc and marathon events, a host of trail centres, 12 months of neglect in Ireland, trips to Madeira and Italy for uplift riding……. more than 4,500 miles of not easy off road riding.
The bike is great and still puts a smile on my face. Keeping it all running smoothly and efficiently costs time and money.
And to answer the question – have a look at getting a Turner and using the grease ports regularly to keep all the bushings running smoothly through the grot. You will however have the same issues with every other component. Try for Hope of King components (hubs, bottom brackets and headset), SLX running gear and Hope Brakes. Oh and no dropper. Then learn how to maintain and lube your suspension forks and do it.
crashtestmonkeyFree Membermountain bikes are heavy, slow, inefficient and, as you’ve discovered, expensive to run.
Yes, it is.
Road bike. Sorted.
The topic ‘Best value trail bike at the moment to replace Specialized Camber Evo 2015’ is closed to new replies.
