Help me upgrade my Voodoo Bizango!
Had it for about 4 months and absolutely loving it. Riding mainly up on natural trails in the Quantocks, with odd trips to FOD. Planning on trips to Afan and Cwm Carn soon, and exploring Exmoor too.
Only thing I’ve upgraded is the pedals (NS Bikes Aerial Pro)
Been toying with the idea of upgrading the forks (currently the stock Radion Air 120mm, 15mm axle) – what would people recommend?
Would I be better of upgrading anything else first?
Here’s the current spec :
OVERVIEW
Approximate Weight (KG): 14.3kg
Exact Frame Size: 18″
Forks: 120mm Suntour Raidon LO air suspension fork with lockout & 15mm through axle
Frame Material: Alloy
Front Brake: Shimano BR-395 Hydraulic Disc Brake 180mm rotor
Number of Gears: 27
Rear Brake: Shimano BR-395 Hydraulic Disc Brake 160mm rotor
Wheel Size: 29″
DETAILED SPECS
Cassette: 11-34T
Chainset: Shimano Alivio FC-M431, 44/32/22T Octalink
Fork Lock-out: Yes
Fork travel: 120mm
Frame Colour: Black
Front Mech: Shimano Alivio FD-M431
Gear Shifters: Shimano Deore SL-M590
Gender: Mens
Headset: 1 1/8 Aheadset
Hubs: Formula hubs – Front 15mm through axle
Pedals: Wellgo alloy platform with toe clips
Quick Release Front Wheel: Yes
Quick Release Rear Wheel: Yes
Rear Mech: Shimano Deore RD-M592SGS
Rims: Double wall alloy black 32 hole disc rims
Saddle: Voodoo Branded – Steel Rails
Seatpost: 400mm Alloy 31.6
Stem: 80mm length Aluminium – 31.8mm bar clamp
Suspension: Front Suspension
Type: Mountain Bikes
Tyres: Maxxis Ardent 29×2.25 tyre w/ Wire Bead
