My experience with the top guide only MRP device was very frustrating. Unless you’re using one of the new clutch mechanism rear derailleurs, a top only guide will still result in the chain coming off the lower part of the big ring.
This should be a problem, as when you pedal forward the chain should just come straight back on. But with the MRP, what would frequently happen is that the chain would torque up against the inner part of the guide and push the back plate inwards, causing the chain to then drop and wedge down between the ring and back plate.
The e13 ones don’t have this problem because the back plate is stiffer. I don’t know whether the superstar ones would have the same problem as the MRP, it being a cheaper option and all, but the e13 single guide is under £50 anyway so that would be my choice.
