**** off!!! That better?……
If it helps, no…
You only ever need one exclamation mark, and there are only three dots in an ellipsis. Whether or not you should use ellipses after a question mark is also dubious. Sorry. 😉
(Crosses fingers, hoping there are no errors in this post…)
Apart from that, Formulas have a great reputation and feel brilliant, but I’ve not used them much. You can get deals on them direct from Formula, although I’m not sure if there are any Megas.
Shimano I’ve used for ages. Loads of power (I use 180mm front, 160mm rear for everything, but would happily drop to 160/160). Great, slightly squishy feel, for me at least. The new levers are a touch shorter than I’d like though. A big downside for me is the lack of spares. When a seal goes, you need a new lever/caliper/whatever – which is annoying. That said, I’m using new SLX, and new parts aren’t too pricey.
EDIT: Go here for Formula’s offer on a set of Megas.
