Viewing 15 posts - 1 through 15 (of 15 total)
  • Beech kitchen, dark worksurface – what colour flooring?
  • Xylene
    Kitchen units are beech, work surface is some sort of dark black speckled stuff.
    What colour should the floor be? Beech or will that be beech overkill.
    Also what colour would you tile the walls?
    Floor is more important though.
    PeterPoddy
    Ours is close, light oak. Dark quartz worktop ( better than granite) with dark floor tiles with a very subtle metallic flake in them
    IMG_0701 by PeterPoddy, on Flickr
    IMG_0707 by PeterPoddy, on Flickr
    Floor us still partly wet in the pics
    Blazin-saddles
    Dark to contrast the units would be my call, beach on the floor as well would be a bit OTT. Wall tiles could be pretty much any colour you wanted with that colour scheme.
    igm
    Floor – Slate
    Wall – Hmmm… cream maybe
    neilthewheel
    Dark floor, whatever you do – unless you want to have to mop it every day for the rest of your life.
    PeterPoddy
    Other direction
    IMG_0710 by PeterPoddy, on Flickr
    We went for stronger colours. The main Walls are a retro yellowy-green. One person said we were ‘brave’ to use those colours, but we specifically wanted to avoid neutral colours as that’s what everyone has. :). We think it’s come out better than we ever could have hoped. I installed the units and appliances myself. It’s not hard. Worktop is a pro job, as is the tiling
    Xylene
    What is the floor made from?
    PeterPoddy
    Oh, as to can see, no tiles in the whole room. 100mm upstands to match the worktop, plus extension including the windowledge.
    Job has a custom sized SS splashback, £45 ish off the Internet somewhere.
    PeterPoddy
    Floor is porcelain tiles that look like a modern slate. Smooth finish though ad we needed to stand a table and chairs on it and don’t want them rocking. £600 for the tiles alone.
    pjbarton
    As a rule of thumb, keep planes the same. Floor and tops especially. Units and tops in wood or units and floor looks ott. The other issue would be the ‘nearly not quite’ mismatch issues of different woods
    Xylene
    My walls are shocking so the tiling will cover the worst of it up
    tonyplym
    Rubber floor tiles work really well in a kitchen – I went for a nice bold “Pacific Blue” and am well pleased with the result (easy to clean, really hard wearing, warm underfoot). Not easy to fit though – I would advise against DIY as the waterproof epoxy adhesive used to stick them down means you only get one chance to get it right, and mistakes will be expensive (and very difficult to put right).
    PeterPoddy
    I had to knock a stud wall out of that room, so it was all plastered and new electrics installed at the same time.
    Hence perfect Walls and not needing tiles. 🙂
    PeterPoddy
    Double post
    sslowpace
    We have a black granite worktop with very dark grey porcelain floor tiles. Looks great against walnut cabinets.
The topic ‘Beech kitchen, dark worksurface – what colour flooring?’ is closed to new replies.
