- This topic has 38 replies, 24 voices, and was last updated 10 years ago by Drac.
Bedding in Pads
r8jimbob88Free Member
Just after a rough general censous. Do you bother to bed your new pads in? If so, how do you do it?
I have always done it, no idea why i’m doing it but just think thats what your supposed to do…
I usally do a number of heavy braking stops until they go super hot. Is that the best way to do it or is it a better idea to do more progressive style braking?
Input welcome, as is “just ride and stop fannying about”.
coreFull MemberAre you racing or riding competitively?
If not, “just ride and stop fannying about”.
ruggerbuggerFree MemberRide & stop, repeat a few times & then fanny about!!!! 😉
r8jimbob88Free MemberYep I do race XC and ride other competitive events.
I have an event on Sunday and have just installed new pads and wont get chance to ride before then. Will I die a horrible death if I dont bed them in?
lovewookieFull MemberI never used to back when your choice was hope or EBC, as they would tend to be OK from the go.
With a lot of the new cheaper ones you need to warm them up under as controlled conditions as you can, hence the bedding in bit.
I have found that not only the cheaper, but the brand name pads can break off from the backing if I didn’t ‘bed’ them in. That’s not a scientific study by all means, but something I’ve noticed when posing the question of whether to bed them in or not myself.
andysredminiFree MemberI read an interesting article written by a technical person from a pad manufacturer that said bedding is essential for best performance and durability.
By getting the pads very hot under compression you are essentially performing the final stages of the pad material curing process.Their advice was to find a hill. Ride down and brake hard then squirt the brake with cold water and repeat a few times.
I always do this now but have no evidence that it improves performance or durability other than my brakes (hope m4 tech evo with organic pads) work very well and pads seem to last ages even in the mud.
Andy
r8jimbob88Free MemberDoes the compound make any difference to wether of not you bed them in? eg Organic, sintered etc?
Ive just intalled Shimano’s own XT pads (what compound are these?!) I’ve not had much luck with Superstar pads so far.
bigyinnFree MemberContinue to do what you are doing and you’ll be fine. If you go straight into a race with unbedded pads they probably wont bed in and will worn down by the inevitable filth without ever getting hot enough.
For the sake of a few hard stops in the dry, why wouldn’t you?OnzadogFree MemberI do. Rather than stopping, I slow so as to set up a layer of pad allthe way around the rotor. Pressure and heat together are what you need.
walla24Free Member100% definitely worth it in my opinion.
10 or so quick stops and you can feel each one getting stronger
r8jimbob88Free MemberThe event i have on Sunday is in Edale (for those of you that know the area). I guess I could park at the top near Mam Tor and then bed them down the huge road descent on the way…. Sounds like a plan to me
stumpy01Full MemberOnly time I’ve not bedded in pads was at a wet Dusk ’til Dawn.
2 laps later and the new pads were down to the backing plate.
I always bed them in when I can – 10 to 20 x go as fast as I can, then stop as hard as I can seems to work.
As you’d expect, you can get the front brake a lot hotter, quicker than the back. So if replacing front and rear, I tend to do one set on the front, then stick those pads in the rear and do the second set.jairajFull MemberA few sprint starts and sharp braking round the car park will have the same effect.
You simply need to get the pads hot without glazing them. So any short sharp braking from a reasonable speed to get temperatures up should work.
Don’t drag the brakes down a big hill as its easy to over step the line and glaze them.
Also as far as I know the water thing is just to tell whether the pads got hot enough ie it’ll sizzle or evaporate very quickly if the brakes are hot. Don’t think the water aids the bedding in?
r8jimbob88Free MemberStumpy that is a genius plan! Why havent I done that before!
nealyFree MemberIt’s definitely needed and makes a difference. I find it easiest to do it on the biggest road hill you can as it lets you do repeated hard brakings in a row building up speed easily inbetween then ride back up to the top and do it again until it seems done…and then do it all again for the back brake. It’s needed every time you change pads and is probably needed occasionally after riding in filthy conditions which will remove the pad material from the rotors.
This is about car brakes and quite wordy but it’s the same materials and concept
https://www.essexparts.com/learning-center/cat/brake-rotors/post/Bed-in
edit: you need to bed in the pads and the rotor so would need to put the rear pads and rotor on the front.
jools182Free MemberI found I have to do it on the rear brake as otherwise it will eat a set of pads in a few hours of riding
I take the new ones with me on a ride, climb up to the top of a hill, put the new ones in, and blast down braking a few times
DracFull MemberI take the new ones with me on a ride, climb up to the top of a hill, put the new ones in, and blast down braking a few times
Yeah that’s called riding your bike.
NorthwindFull MemberI always bed mine in, ime there’s no question that it works better if you’re dealing with wet conditions. Not so important in the dry.
I had some weird experiences with kevlar pads, because I always used to just do hard stops til the brakes worked. Kevlars actually provide good power almost immediately, so I just did a stop or two then, er, stopped. Cue erratic braking and fast wear. So I tried again and bedded them in the same as I would a sintered pad, even though they don’t feel like they need it. Cue excellent braking and slower wear.
fr0sty125Free MemberI always do it.
Sprint followed by hard breaking repeat a few times until the pads feel good.
100mphplusFree MemberEasiest way to bed in pads is to use some water and a flat stone / paving slab / or in my case I use a chisel sharpening stone.
Wet stone, rub brand new pad on stone in circular motion to create a nice black paste. Clean pad and stone with clean water and repeat – sorted.
If you’re bedding in a new disc too, use some damp wet and dry paper on it. Fold paper and hold onto disc either side and spin wheel a few times to just take the polish off the disc, then clean with water.
Little trick used by motorcycle endurance racing teams when there is insufficient practice time to bed in all the pads required 😉
globaltiFree MemberThe fallacy of the need for bedding in bike brakes has grown up thanks to a few technical articles on the web about material transfer to new discs on road cars, which get much hotter and have a bigger job to do.
Just get on it and ride.
stumpy01Full Membernealy – Member
I did wonder about this, but I haven’t noticed an issue with bedding-in on the front and then transferring the pads to the rear. It might not be quite as effective, but I haven’t noticed any real difference.
globalti – Member
The fallacy of the need for bedding in bike brakes has grown up thanks to a few technical articles on the web about material transfer to new discs on road cars, which get much hotter and have a bigger job to do.Just get on it and ride.
Don’t really care about the technical articles or science behind it. It seems to make a large difference to pad life in my experience. That’s good enough for me, for the sake of 10 mins spent riding up & down the road.
jools182Free MemberDrac – Moderator
Yeah that’s called riding your bike.The pads would be half gone if I put them on before getting to the big hill I use
NorthwindFull Memberglobalti – Member
Nope, it grows from people doing it and seeing it works.
makecoldplayhistoryFree MemberI do it, because I like braking hard. By ‘it’, I mean I accelerate hard, brake hard and repeat x5 / 10 times. Then I touch the disc, think “ow, I won’t do that next time” and ride. It’s mostly so that I know I’ve set the brakes up properly.
I asked someone about it who was involved in F1 and the manufacture of brake pads (among other components) for fast cars. He thought the idea of us lot bedding in pads was hilarious; the pressure and temps that the pads undergo during their manufacture are many orders above what we can create. He said that we might burn off a little residue from the factory but that that would happen anyway; there certainly wasn’t any long term benefit.
However, what would an automotive engineer at the top of his game know compared to the average STW’er 😉
The other two thing’s he said were 1. buy a red bike for 10% extra speed (that’s why Schumacher won for so long) 2. don’t wash your shorts before a race and always put your right sock on first or you’ll never win!
MilkieFree MemberYou don’t need to bed them in, but they last longer and brake better if you do.
My friend didn’t bed his in and they lasted half a day compared to the set he did bed in which lasted 3 days in the Alps.
nealyFree MemberIt’s about getting an even layer of pad material on the rotors which increases friction and stops them being noisy which happens when the pad material is not even.
NorthwindFull Membermakecoldplayhistory – Member
And does he actually ride a bike and have any direct experience? We have a bunch of incredibly clever mechanical and process engineers, and a bunch of technicians who are all like shaven monkeys but know how to make the engineers’ ideas actually work 😉
seosamh77Free MemberGenerally, just riding will be fine.
But if you are changing your pads and end up riding in really wet gravelly scottish mud, this can destroy your pads.
I replaced a set of pads in torridon in such conditions once, the pads lasted about 3 hours.
stumpy01Full Membermakecoldplayhistory – Member
Yep. Because F1 is just like riding a bike through a sand/grit slurry.
Don’t care what fancy pants automotive engineer at the top of his game knows. All I know is that when i bed pads in, they last many months and when I don’t bed them in they can last only a matter of hours – particularly in wet/gritty conditions.
I’m an engineer and have heard so called ‘experts’ on various topics say things with real conviction that turn out to be nonsense once you run a few experiments….
DracFull MemberThe pads would be half gone if I put them on before getting to the big hill I use
Try fitting them properly next time.
Never done it and never had an issue. Funny that.
akaskittlesFree Memberpedal till 10mph, stop without feathering a few times and done!
NorthwindFull MemberDrac – Moderator
And “not having an issue” means it all works identically, and you not having an issue means nobody else ever could.
seosamh77Free MemberDrac – Moderator
Never done it and never had an issue. Funny that.thats that settled! the oracle of no experience has spoken! 😆
DracFull MemberTrue but it gets the same result of those who claim to bedding them in works which is what counts.
You can say that about bedding them in too. My point is it makes no difference.
The topic ‘Bedding in Pads’ is closed to new replies.
