Same dimensions. Now, do you want max compliment? Stainless? Chromium? Ceramic? Hybrid? LLU seals? LLB seals or SRS?
£25 for 4 bearings isn’t that expensive if they’re a quality brand. Or do you mean each? In which case, that’s way too steep.
What was the failure mode of the current ones?
Failure – bearing inside freewheel seized … it freed up when knocking out but still feels like crap… rusty
The hubs are Novatec D772 it’s a really light hub but not all that strong …hub strength with a 25kg kid riding isn’t a problem but knocking the old bearings out the soft alloy inside probably will be if I repeat multiple times. (Since the wheels have close to £100 worth of spokes at RRP I don’t want to change the hubs i only paid £1 a spoke for CX ray when building but that took a while to buy) anyway point is want to get maximum life out of these wheels and feel knocking the bearings out more than I have to out will not be great ! Especially if I keep using the steel bolt that is just the right diameter …
It’s mid XC season so it would be really crap having to put on a wheel 3x the weight for a race.
Last weekend we rode downhill… perhaps I should have changed wheels… but I don’t think it had anything to do with the failure he didn’t case any jumps badly and he only weighs 25 kg … or 26 with full face and pads
As it happens I picked up a set of spare hubs when superstar did some clearance so I just stuck in the spare freewheel for now. The freehub bearings I pulled where 6902 2RS the ones on the new but later model spares inside the hub itself are EZO made in Japan 6902-2RU. The ones I pulled are NSK with no country on manufacture who I believe also manufactures in china.
I don’t know what bearings are inside the in use hub (my eyes aren’t that good and I didn’t fancy knocking them out with the bolt just to find out) but they are the same diameter my guess is they are the same as the ones in the freewheel just they switched bearing suppliers and bought bearings made and engineered in Japan rather than made in China ? But what does the RU signify ?…
£25 for 4 is fine … £25 each is more than a new hub…. and I can get a new freewheel for £40 … I’d probably pay someone with the right tools to actually install them rather than bodge it.
No idea … the ones that last the longest …within reason which I guess goes down to seals, matierial and manufacturing tolerances.
