I’ve got a problem with my Superstar (rear) hub and the drive side bearing. Hard to get out, almost impossible to press in I’d assumed the tolerances were off, but perhaps it’s a more common issue.
OP, once you have the old ones out, you need to press the new ones in using the a socket on the outer race rather than banging the inner. If you hammer it back you risk damaging the balls and races.
So the top pic that’s the side you press them in? So I turn it over (bottom pic) and hit them out from that side?
Looks like it.
Edit – but make sure you don’t collapse the bearing and leave the outer race in there or it’ll be a complete arse to remove.
