I’ve replaced most of the pivot bearings on my Canyon Spectral, using a screwdriver and mallet to carefully extract them and then a socket and hammer to carefully drift fit the new ones back in.
All ok so far…. however, there is a linkage point at the end of each chainstay, next to the rear hub, where each chainstay arm has a pair of bearings fitted back to back. i.e. Each side of the rear of the chainstay has a bearing press fitted into it.
How do I extract these bearings best?
I guess that I could use a blind bearing puller (the hammer type) to try and extract these, but I’m concerned that if the bearing collapses (as some have on extraction) the centre race will come out and I’ll be left with the main outer race stuck in the chainstay ( how on earth do you then remove that with no way of getting access to the rear of the bearing ?)
Advise and wise words gratefully received 😉
