Went to the LBS for bearings on Saturday I needed three. Two I checked roughly in the shop since they were in plastic bags, the other was in a box inside the bag. The outside was labelled 6001 so I thought it would be okay.
Got home and it was the last one I fitted, and it turned out the inside diameter was too big by a mm or so. So I checked, and the box said 6100 on it, even though the bag said 6001. Hmm, I thought, someone’s made a number mistake, easy to do. Except laser etched onto the inside race is 6001.
a) Eh? Why, if the right size is etched on the race does it not fit? I thought (and was told by the guy in the shop) that only the numbers dictate the size and the rest (LB, 2RS etc) are just the type or the seal type.
b) Should the shop give me a refund? Removed the bearing but damaged it a bit knocking it out. Would you expect the shop to fess up to the mistake and keep the customer sweet for the sake of a fiver? Or is it my fault for not checking it carefully enough before fitting? Even though the exterior label was verified correct by the both of us.
