my 2015 Cannondale Super Six Evo 105 has PF30 with Cannondale’s own aluminium alloy cups pressed into the PF30 frame shell, and then BB30 bearings pressed into those cups
Of course after 2 weeks it was creaking like a old door so I ditched the FSA chainset and put a Wheels PF30 BB in there and Wheels nylon adapters for Shimano Ultegra HT2 crank – this stops any metal on metal (bearing to crank axle) contact which prevents fretting corrosion and creaking
If you know Shimano HT2, they designed their system with a nylon top hat on each HT2 bearing to achieve the same aim- a problem with many of the conversion BB is they have an oversized bearing with no nylon top hat, meaning the HT2 axle is against the metal bearing seat.
I’ve had conversion BB’s before and generally found after a few weeks of wet weather or bike washing any grease between crank axle and metal bearing has flushed out, creaking starts, becomes a regular boring maintenance chore to remove and refit with fresh grease
