Viewing 5 posts - 1 through 5 (of 5 total)
  • BB71 and cranks – What will fit?
  • ffej
    Morning.. I’m confused.
    I have a 2012 Giant XTC frame on its way to me which according to Giant needs a BB71 press fit BB, which is fine, they seem to be readily available, however they mention “89.5mm/92mm Shell” in the description which is much wider than the HTII BB’s I’ve been used to (68/73mm). Will my old XT cranks fit, or do I actually need a whole new crankset?
    Jeff
    flange
    I have a bb71 in my cube road bike. Used my old HT DuraAce cranks that had previously run with an external BB and its fine. Well, I say fine – press fit BB’s are utter shite and whoever came up with the idea should be shot
    nigelb001
    The width of the shell is the same as external bb shell + width of cups so any HTll or Megaexo cranks and spindle will fit. You just need the correct press in bearings.
    perthmtb
    Remember the bearings on a press-fit are inside the BB shell, so if you added the width of the bearing cups to a normal 73mm BB shell you’d get… ta da … 92mm! So, yes, any Shimano HT-II cranks will fit a press-fit BB71 (or BB51 and BB91 for that matter – they’re all the BB92 standard.) Damn – beaten to it…
    ffej
    Ahh, it makes sense now. Many thanks everyone
    J
The topic ‘BB71 and cranks – What will fit?’ is closed to new replies.
