Viewing 11 posts - 1 through 11 (of 11 total)
  • BB7 & Shimano Post Mount. Friends?
  • cfinnimore
    BB7 caliper, 203 rotor, Shimano adapter. Post to post
    I’m staring at my fork leg, it’s staring back.
    Caliper/ adapter interface sadness
    cynic-al
    Are you saying it doesn’t work, or asking whether it should?
    cyclistm
    If there is a problem you probably need some washers, google AVID CPS.
    cyclistm
    cfinnimore
    It doesn’t work as far as I see.
    Should it work?
    cynic-al
    I think you might just need the washer bits like off V brake blocks.
    cfinnimore
    Longer bolt, extra washer. Fixed.
    Now, fitting BB7 to rear of slotty inbred.
    Joy
    breatheeasy
    Shimano use 200mm rotors don’t they – would that be the cause of your sorrow?
    joshvegas
    cfinnimore – Member
    Joy
    I didn’t have much problem with that… oonce I took a file to the adaptor… and filed alot of the bolt head off… and swapping to a 180 rotor… and filing the wahers plate thingumy… and making a super stumpy allen key…
    Simple see?
    cfinnimore
    Joshvegas it’s a sad day.
    New 180 rotor, check.
    New adapter, check…..
    No……wrong adapter.
    *sigh*
    cfinnimore
    Now for the usual faff of figuring out why the new caliper, new pads, new rotor, when all together sound like an angle grinder.
    I have deore hydros in a box in the cupboard…talking to me.
The topic ‘BB7 & Shimano Post Mount. Friends?’ is closed to new replies.
