tbh the rotor spokes would quickly shave off any pad material anyway.
maybe they might, but they haven’t. 600 miles haven’t really affected the judder, and the judder is definitely in time with the rotor spokes hitting the pads. Only at medium pressure though, feathering and really hard braking don’t create same result.
If I had a dremel, I could grind away the part of the pads that overlap the bottom of the rotor (pretty obvious, as the pad wear is different) but spacers will be quicker and easier.
Just realised as I was typing that this problem is only an issue because one of the pads is stationary, so as the moving pad comes into contact with the rotor and pushes it towards the stationary pad, the outside of the rotor moves further than the inside, and the bottom of the moving pad is exposed to the angled rotor spokes.
Your hydros will have both pads moving into a stationary rotor (i.e. it’s not being moved away from the plane) so the spokes aren’t hitting the pads in the same way.
Thanks! I wouldn’t have realised that without you mentioning the hydros. It doesn’t really affect what I’m going to do about it, but it’s nice to understand the problem a bit better.
