Soooooo many options to go for, the problem is that none of them seem without their faults!
Has to be said though that the Raceface HT2 BB's seem to be universally regarded as one of the worst.
One option you have is to get the origianl bearings pressed out, and some new ones (which you should have filled with grease first) pressed in. This is perhaps the cheapest route, though of course it depends on the bearings you buy.
Most expensive route would be to go down the route of buying a Chris King BB with the associated regreasing tool. Together they'll set you back well over £100, but from what I've heard, it seems to be the answer to HT2 BB longevity.
Or there's also Hope, Shimano, Acros, Superstar (dare I say it, though I just bought one with SKF bearings in which should last a lot longer than the cheapy bearinged versions), and god knows how many others! Shimano OEM ones seem to last about the longest though of the cheaper BB's from what I've seen. Good sealing and lots of grease in the bearings seems to make a LOT of difference to longevity though…
