Viewing 10 posts - 1 through 10 (of 10 total)
  • BB mounted blackspire stinger
  • tails
    Will this rotate on the bb and go into the chain and chainring?
    bruneep
    mine has never moved since fitted.
    xiphon
    Not if you A) de-grease the contact area, and B ) tighten it up enough
    swingbing
    Mine did to start with. I have now put a little bit of locktight on the drive side BB before assembly. Been fine since.
    tails
    Thats a good idea, glue and possibly give the surface a key.
    Craggyjim
    Mine only moves when I clobber it with a rock, unfortunately this happens surprisingly frequently and is mighty annoying as the chain then gets pinched on the stay.
    bails
    Mine’s never moved, even when I’ve whacked it with a hammer!
    Northwind
    Depends how tight you do it up.
    The downside of doing it up real tight, is that if you do eventually manage to move it, you can’t easily move it back! I keep mine ever so slightly looser, it still doesn’t move often but when it does I can get it back in place without needing a BB tool.
    crashtestmonkey
    some people see this is a benefit, as opposed to having the tabs (ie. part of your frame) damaged when an ISCG-mounted guide hits a rock…
    ffej
    I assume this is only an issue when you’re running without a bash guard.. I have an e13 bash and the stinger roller just touches, it shouldn’t be able to move in that scenario.
The topic ‘BB mounted blackspire stinger’ is closed to new replies.
