The battery charger MUST be Lithium specific.
4.2V per cell is a very precise voltage. 4.1 is not enough for a full charge and 4.3 is too much. Also they don't take overcharge, so a decent charger will have a timeout facility.
There should be a balancing facility to ensure each battery has an equal voltage across it when charging. If you're making up a pack, the individual batteries should be UNPROTECTED. Then they are connected to a specific circuit tailored for the right number of cells. This circuit then provides the power limiting and voltage balance.
Its more complex than most think!
