Check the size of your bathroom and then use one of the online calculators to decide how big a fan you need/want.
There are loads of different types and different sizes and some are noisy while others are very quiet.
I’ve just fitted a large fan (150mm diameter) in our bathroom – mostly because it’s big enough to need the air flow that only a 150mm fan can give. It has reduced the humidity in the upstairs of the house, which makes it a nicer place to be and reduces water damage to soft furnishings etc… and reduced the condensation on the windows when it’s cold outside.
Online Fan Calculator
